problemi rendering
  • Thread starter Thread starter Squente
Squente
I am using another pc with autocad 2008 and after I make my model, I can't save it.. . ..practically render it in the model window and I can't save it in jpeg format or any other format...give me a hand for pleasure:/....usually opened another window and I could safely save it.
in case you hadn't solved yet, open advanced rendering setting and in the "destination" field select "window" once finished the render should give you the possibility to save in the preferred format
