problems in the table development sheet
  • Thread starter Thread starter Stemox
Stemox
in putting on the table the development of a sheet I have an error message and two sides are not closed...I attach pictures.
thinking about a problem I recreated it again with the same result... has it ever happened to you?
Why does it occur?
I also attach model pkg ver.18.0 (zipped)
  • Lamiera.zip
    Lamiera.zip
Why does it occur?
I think it gives you that error message because that side of the sheet is slightly tilted (the one I see in the side view) and therefore the fitting in the plant would be a bow of spline and therefore does not recognize it with fitting in the flat view.
Hello coat of arms,
I press that I didn't understand why it makes you that strange development since removing the two fittings on the corners the development is correct. I think there's some problem related to the model, obviously something infinitesimal probably linked to how you build it.
I tried to make a similar piece also increasing the curvature of the face and to me develop it correctly. image 2 and 3
comunque se vuoi sistemare il pezzo basta che tu elimini i 4 fori sulla faccia curva gialla. con il comando copia faccia selezioni le facce esterne della lamiera e ottieni una superficie.
dopodichè con il comando geometria3d/ inspessisci ricrei il solido spessore 5mm, fai i fori, gli assegni un materiale di lamiera con spessore idoneo e sviluppandolo dovrebbe funzionarti correttamente. operando i questo modo sei sicuro che ogni punto del solido ha spessore 5mm.
saluti, stefano
Hello stefano,
I think we know each other even if you haven't felt any more for a long time. I worked from lions to narni when we took the soft to the bt where you worked. . .
How's everything all right? I'm glad to hear you.
the model I created it starting from two sheets, joining them and forming this model (vertical part + radiated part) I never had problems, but this time happens to me.
stefano muskets
p.s. I sent to a technician to understand why the error
