CAROLINA
Good morning.
I can't understand why I sometimes write the text in a prospective view, then maybe I have to go correct the writing and I can't because it gives me problems in the text, that is, the pointer moves backwards to where it should be erased, it goes to the right instead of to the left.
I don't know how to correct this error and not how to avoid it doesn't always happen, but often.
The only solution I've found so far was to save and close the file and then reopen it and magically doesn't.
Even in writing it becomes difficult because the pointer is not close to the text and does not follow the writing of the text but is moved.
I don't know if I explained.
I attach reference image.
I don't know if I explained.I attach reference image.
