lustro
hello to all
I've been looking around, but I found no solution.
then I have a small problem with swx: here in the office we have 2008 s.p. 0 (they are tirchi and nn update....
), sometimes I find myself having to update old drawings, and to speed up the times I am based on the precendeti :tongue: : for the 3d no problem, I devote everything (including the properties of the file, which then I call in the 2d), then for the table I turn out the old design, in the sense that often I deceive/add/eliminate the quotas and everything ok.
However, it often happens that the drawings are on an old cartiglio, and when I change the cartiglio, swx does it without problems, but they appear as soon as I press "save": a beautiful writing with "unknown error while accessing the file.... " (what is in use).
the fact is that this problem comes to random...someone knows why? ? ?
thank you all!! !
thank you all!! !
