problems with angular bond
  • Thread starter Thread starter mariom
mariom
inventor 2010
hello to all
I have a structure consisting of two rectangular frames,( created with frame module) are connected with each other with a pin and a support.
when I go to give the angular bond everything ok, while when I go to change it to take it to the position I need gives me the error you see in the annex, the values become red and begins to move in a disorderly way.
I don't know how to behave.
gr = degrees
mm = mm
the angle constraints do not dimensional with the mm but with the degrees. if you do not put any unit of measurement should interpret degrees and work the same
thanks for the suggestion, I put the grades and everything went well.
the thing that I don't understand is why the other simulations made me by putting the degrees in automatic, and instead in this file I have to insell them boohhhh.....:confused:
