giocamb
hello to all
I received step asm files and importing them I have problems at surface level.
then I attach images but to understand us there are some areas of mathematics where there should be 0.2mm lower instead in pro/e wildfire5 m06 (I know that it is a little old but unfortunately this passes the convent) the surfaces are reset, I tried to ask a friend of mine to check also on unigraphics if even to him happened the same thing to have a match if it was a problem of export see, invece
in the import I tried both the precision choices both automatic and external but nothing to do, is that probably in the config.pro there is something wrong?
I also noticed that the various details of the assembly year all a different accuracy with each other.
Can someone help me?
