problems with post
  • Thread starter Thread starter isaac
isaac
Good morning to all,
I am new to the forum, I would need help with the post I provided. I use mcx and setting a processing that involves rotation of axes, this reverses the main axis (z) with the secondary axis (y). how can I set them correctly?
Thank you in advance. m.r.
you have to open the post and look for these strings
#assign axis address
str_pri_axis "a" primary axis to
str_sec_axis "b" secondary axis b
you have to change the name of the main and secondary axis in this way
I hope I've been clear! Hi.
hi I have an answer to your problem the post and just so but you have to look at the beginning of the program if there is a g17,g18,g19 these codes sleep the workplans just put the right one (ex,g17 interpolation axis x and y g19 interpolation axis y,z g18 interpolation axis x,z) hope to have been of help
