problems with the dynamic section
  • Thread starter Thread starter vsolera
vsolera
Good morning to all,
I've already looked in all the settings, but I can't solve the problem.
when I do the dynamic section in a solid parts axieme, in the dynamic section in 3d I only see the curves, as if I were working with parts in surfaces. thanks to everyone in advance.
menu/instruments/options/mechanical design/assembly design/sections dmu/section filling (check mark)
I put the check on "allow measurements on a section created with a simple plan".
I went to attempts because I did not find "sectional filling".
now the various parts seziona holding them full only flaw and that are all gray and do not keep their colors.
Thank you for your valuable help.
What's your review?
Filling section corresponds to the symbol of paint can that reverses the color.. .
outside of the menu you can also find it when you apply the section command in section definition/result/options/section filling
I don't think it's a problem of relics (maybe) because I have the same problem...... I directly no xche ho md2-gsd2 and cam and see the sections with filling....... my colleagues with only md2 no!!!! do not have the filling button.
So I think it's a licensing problem... unfortunately also filling x catia has a cost.......
If someone has other comforting news... well come.
cat v5 r20 spk 6
Good morning.
I work with v5 r21 and the license is hd2.
It is probably just a cost problem and in my license it is not included.
I also looked directly on the command, but nothing
in fact you have to activate a dmu license seems to me dmu-spa I could check Wednesdays at work
I checked.
You must have the dmu spa license.
also you have to activate in the options:
allow measures on a section > tools > options > assembly design > dmu-sezioni[FONT=Segoe UI,Segoe UI][FONT=Segoe UI,Segoe UI][/FONT][/FONT]
