Catafratto
I often do axiemi (saldati and no) that lend themselves particularly well to work together, for example drums for conveyor rollers where I first create the welded "grick" and then do the various processing (to be able to have the separate tables). problems arise when I go to change the "grezzo" also apparently innocently, for example by stretching or shortening the drum tube: sometimes the sketches of the workmanship do not update, the edges that should move do not follow the parts and everything jumps. I couldn't identify a way of working more resistant to variations so I don't even have a clear idea of how to proceed or what advice to ask.
I ask you if the work together is a little unstable for everyone (and so I put it away) or if someone uses it with satisfaction thanks to a workflow that guarantees stability even in case of variations.
I hope I've been properly explained. . .
