procedure to perform modelcheck in batch mode
  • Thread starter Thread starter painaz
painaz
warning: I'm not a ptc technician. before applying procedures do all backups of the case.
procedures tested on wildfire iv and
in the previous post I indicated a procedure to make modelcheck a task
specific using custom configuration files.
now we see how to automate procedures, for 100, 1000 files at a time
preliminary operations
I create a directory where modelcheck "down" files reports of what it does in batch mode
example:
x:\directory_departure\modelcheck
open the file
x:\dove_installed_proe\modchk\text\configconfig_init (first make a copy of it! ! ! ! )
I focus on voices:
# directory modelcheck will write reports on nt
#dir_report_nt $temp/mc_reports
# directory modelcheck will write reports on unix
dir_report_u /tmp/mc_reports
#dir_report $temp/mc_reports
and I change that dir_report (check that there is no #, otherwise it is a comment)
dir_report x:\directory_di_partenza\modelcheck\mc_reports
for scruples I also put
# config select mode - automatic (y) or load config menu option (n)
# or ask user at start of pro/e session (a)
cnfg_select_auto yna y
(previous example on a, ask)
(if you have wildfire i, otherwise do before and mile on tools configure modelcheck)
I create a batch file that lists files to test.
the batch file to create the list will be:
echo
dir x:\dove_are_i_file\*.prt* x:\dove_are_i_file\*.asm.* /b /s > x:\directory_di_partenza\modelcheck\list.txt
in practice are listed only prts and asms of any numbering (that is why *.type.*) without additional information (option /b) of the indicated directory and subdirectory (option /s) and redirect list from the video to a list text file.txt (option > )
create a link (put it on x:\directory_di_partenza\modelcheck) that points to this file:
x:\dove_installed_proe\bin\modelcheck.bat
launch the command, appears:
step_2.webpselected batch modes, with "browse" pointed to list.txt created by list.bat
the proe/start command must simply point to x:\dove_installed_proe\bin\pre.exe
now modelcheck, grind, do what you have to do and create two reports, a text about
x:\directory_departure\modelcheck called list.txt.mc_tmp
an html "infognato" (I don't know if it is possible to indicate where to create it) on (in case you have xp)
x:\documents and settings\mio_username\dati application\ptc\proengineer\mdlchk
which is called: batch. list.t.summ.html
If you open it comes out like this:
step_3.webp[Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep] [Bleep [Bleep] [Bleep [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep [Bleep [Bleep] [Bleep] [Bleep] [Bleep [Bleep [Bleep] [Bleep] [Bleep [Bleep] [Bleep [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep] [Bleep [Bleep [Bleep] [Bleep] [Bleep [Bleep [Bleep] [Bleep [Bleep] [Bleep] [Bleep [Bleep [Bleep
wildfire the
the wildfire i does not have a "wizard", disogna fare tutto textuali
the command to launch has syntax:
modelcheck executable_proe -f file_list -c file_configuration_specifica
then you have to create a batch file of the type:
x:\dove_proe\bin\modelcheck.bat x:\dove_proe\bin\proe.exe -f x:\dove_list\ list.txt -c x:\dove_proe\modchk\text\config\config.gmc
if you have localized Italian, otherwise the configè on ....\usacii\config.gmc
Stop.
if you have suggestions or find errors the reports are well received.
