processing stl
  • Thread starter Thread starter rocchio
rocchio
Hello everyone,
Who can tell me if there is a command that you create as a skin that wraps the model to be able to work it in mfg?
I'll explain... I should make a marble lion head, as I have a stl file and I saw that proe does not read the surfaces, so with freecad I turned the stl file into iges... The problem is that everything faceted and every triangle is a surface. .
So I wanted to know there was a way to create one more uniform surface... I tried with shrinkwarp but it doesn't create anything.
Hello everyone
the stl file is a cloud of points, you do nothing unfortunately... you should have the tool that uses reverse-engineering to produce fast and faithfully leather as you call it and have a manageable surface.
I know [MENTION=79]maxopus[/MENTION] He uses it. I don't know
I confirm what is said by calacc, with shrink-wrap you do nothing, you need the specific module (rex) and you need to know how to use it.
rather it would be preferable to find someone who has a cam that reads stl ... shaping the head of a lion is not a 3-minute thing.
