panormus
if the geometry to be realized is not complex you can do so:
project any sketch on the surface,
cut the same with the projection,
create a cut surface offset (e.g. a square),
and you will have a perforated bin and a sketch shape offset,
then create a connection surface between the offset sup and the perforated surface.
I used the same technique for the auditory r8 I designed.
clearly then with the beauty of the parametric limit you to change the parameters of the matrix.
