Gnomas
as from title, I am mobilizing to create in inventor, a project of a 2tempi engine.. .
I want to point out that I am self-taught and that therefore many tricks and various robes do not know them, that is why I come to ask you help!
Now I don't know if any of you are experienced also of engines, I cmq will try to make me better understand:finger:
I have various problems I couldn't solve, like:
1) in creating the headboard, I need to polish in mirror the zone of the blast chamber (it would be a job to do post-production of the piece), but I can only mirror the whole full head instead of mirroring what I need.. .
2) in creating the side beams (they are simple windows that "look" inside the cylinder), I can only create them so that their axis is in line with the horizontal axis of the circumference....while I should make sure that lancino towards the exact center of the cylinder, in any position on the rectangular circumference I put them... I tried with the "face" command but I can only tilt the line that corresponds to the whole window .
3) in creating the discharge, drawing the sketch in the horizontal axis of the cylinder, and then extruding it by cutting it up to the diameter....however being circular, a portion of the extrusion goes also beyond the cylinder, while I would like to succeed in making sure that the extrusion is limited only to the circumference of the cylinder
4) the discharge piece where you will go to insert the muffler I should do it tilted down to the cylinder, while I can only do it perpendicular to its axis....I should therefore tilt the whole face, I think it is similar if not equal to point 2
I hope I've explained so and that someone knows how to help me:biggrin:
