programme
  • Thread starter Thread starter danalvez
danalvez
hi to everyone, I have a problem with the selcom program of the selca, I have to install it on a pc with windows 10 32bit,
In fact, I did this, the problem is that I can only download the programs from the machine to the computer,
But when I try to charge them, it gives me an error: transferring incomplete data, someone can help me solve it.
stupid question: the program you used it first on another pc, is it a first installation?
If you're patient on Thursday, I'll watch and let you know.
I advance that on that computer combined with cnc ho win7.
I hope your problem is not win10.. However if charging from cnc to pc means that the software works.
Did you check that the transmission channel on the cnc works?
in any case cnc and pc communicate via serial port right?
If I don't remember badly with the f4 key of selcom you can configure the folder on the pc
ah. a thing that came to mind now
have you checked both on the cnc and on the pc the speed of baud transmission? must be equal
ciao @danalvez as I promised you I'll attach you image of my configuration
see if you can help
so many years ago we installed on a 3045 selca machine the ethernet card to ship the programs from the cam.
were the times of win xp.
everything worked properly.
upgraded to win7 we had to remake the configuration, the system worked until the first restart of the system, then stop, no transmission.
moral: from win7 onwards the system does not work, i.e., it works until reboot, then it must be reconfigured, every time, therefore it is useless.
technical words enabled selca....... .
with the 4000 series controls instead, we use a shared folder on the server for program exchange, and it works perfectly.
First of all thanks, the configuration and as I set it up, I read on the forum that I should change the software, i.e. buy the software sercom , always of the selca , which would work on versions of windows later to me.
I thank you for your availability.
the board installed on 3045 instead, apart from the exaggerated cost, is mounted as an optional module on the control in the electric cabinet, and has an entrance with rj45, then a lan socket that must be connected to the network.
of the sw, however, I do not remember the name, but it must be installed both on the pc and on the control and “will consent” to the two to communicate.
At the end, we mounted a floppy to usb module instead of the floppy, and we go key.............
Staff online
