prohibit opening read-only to networked files
  • Thread starter Thread starter joe
joe
Hello are gianni
network work with autocad 2013; of course all dwg are shared and if I open one to work on it, another person can open the same read-only file:
Would you please tell me how to prevent the opening of a file that is already in use?
I don't think it's possible to stop the opening. but then I'm sorry, if you try to open it and see that it's "locked" (opened by a colleague) you just want it back and amen, don't you? What's the point of preventing the opening?
use the save by name and save it in another location. once modified the latter, they can replace it quietly (with the same name), when I closed everything and went home
I would like to prevent another user from opening a dwg file that is used by me on the network.
Well, if that's all it takes much less. even with a hypothetical protection on the file you open can always copy it to local and do the same trick :biggrin: (uncomplicate your colleagues)
If that's the problem, you'd need it. autodesk vault. with this software you always have the changes made to the file and you always know who changed what.
but even if I put the pw to the file, it is equally open on the net, if in another location is already open by me?
If you put the password on it, the file only opens the person who knows it! But if you forget it, you're fucked. . .
Move it locally when you work there, so colleagues won't find it anymore.
When you're done, put him back in his place.
