proiezione di curve
  • Thread starter Thread starter Giacomanu
Giacomanu
Hello everyone!!! My "problem", is that of having to project curves on a cylindrical surface, I remember having done it already, but now I can't... Hello and thank you
insert - curved from curve - project.. .
If you don't remember where the commands are there is a fantastic command in the help called "command finder"... you put them in "project curve" and he shows you where he is... if the prizes above enter directly or command.
Thank you very much for the answer... But with this command, I don't do what I wanted, but now I try to find the right command for me.
hello and thanks again
What version do you use?
if you use nx4 : insert - curve from curves - project where there is written "direct method" selections "equal arclength"
if you use nx5, 6 or 7 : insert - curve from curves - project where there is written "projection direction" selections "along vector" and then lower where there is written "projection option" selections "equal arc lenght"
I hope that's what you need
sympaticissssssssimi, but I practically didn't need to project the curve, I just had to do it in another way... Anyway, I'm still thanking everyone. I'm going to vacation. Hello again
typical example of one who no longer wants to be helped:mad:
