project flat model and explaining rule
  • Thread starter Thread starter Filo
Filo
I passed from the "factork_di _default" explaining rule to "compensation fold" but when I project the flat model gives me error saying:"flat model projection: detected problems during the execution of this command. impossible to update the flat model. the reference explaining rule is not supported by the previous flat model. to solve the problem, eliminate the flat model and recreate it. Note: the elimination of the flat model from the side causes the elimination of all flat model views in the associated designs."
ideas of why?
can you solve the problem or should I use "factork_di _default"?
attached a scrren shot of error messaging
I forgot. . .
no problem creating the flat model and if I delete it and regrow it as it says in the notice nothing changes, it always gives me the same mistake
it seems to me that from the wreck 2012 they have changed the rules of the sheet, so if the detail and its flat model was created with previous versions once converted to 2013 and updating the rules of the sheet returns the error. for this by erasing the flat model and regenerating it all works
I have error even when I leave from a new sheet.. .
At first I also made your own reasoning and thought the reason was related to the fact that the sheet template was still created with previous versions. I tried then starting from the new 2013 template but it generates the same mistake.. .
styles should all be updated. when I open a new sheet does not warn me of conflicts between styles.
Sorry about curiosity, did you try? on your report any notice?
sometimes even to me from this error, precisely when I have a particular done with previous relics and add work, opening the flat model returns the error and erasing it and regenerating it all works.
I can't get out of it! to create the flat model no problem, but if I project it nothing to do.
not to lose styles and settings I copied the design folder given in the step from 2012 to 2013 and maybe this creates problems, but also taking the default project file, default style folder and default template I have the same error.. .
Thanks again.
I hope there is some other soul of good will with some ideas.
