project help in ansoft designer
  • Thread starter Thread starter mat_tlc
mat_tlc
hi, being at my first experience with ansoft designer, I would need someone more experienced to describe the steps to follow to implement and simulate a wilkinson combo(e.g.:wilk_x).I have a central frequency of 3.6 ghz and characteristic impedance of 48 ohm. thanks in advance for your collaboration:)
I'm afraid you won't find much help here... we are hard on the structural part, but not on the electric one.. .
I would have for + need someone experienced with ansoft designer, can assist me step by step to realize this project. because I repeat, it is my first experience with such software and I really need to understand, in the jargon, where to put hand. I think I'm in the right forum, where to find people who have experience with that cad or are they wrong? Thank you.
maybe there'll be someone who'll come by and help you.
i remind you that you should comply, being new to the forum, to the rules and, as is practice, to present yourself in the dedicated section.
thank you.
thank you.
okay, what's the section?
Well, look through the ots (now I don't remember but there is the function found)
to the max presented here that is fine the same.
Okay, then I'm waiting for your kind collaboration x the project...it's urgent please! thanks in advance
a council: if others do not arrive or should arrive late anyway datti to do; there will also be a help and a user manual.
try because, as stefano said, here we are more structors than anything!
Always refer to the wilkinson divider, can you tell me how to get the distance between the two exit doors so that they don't bother? Thank you.
so as you say that here, for the major, you are structuralists. Is there at least someone who can give me support on using ansoft designer?
if they don't answer you yet means that either they can't help you or someone who can help you hasn't read yet!
