Steel59
I have a set with a diaphragm that fits on a pin.
to create the pocket on which to stay the diaphragm I used the bolean function 'remove'.
the problem is that by wanting to perfect the pocket I can not project the geometry obtained from 'remove' on a sketch.
are the profiles obtained from the boleane functions projectable or is it necessary to use some artificio?
