properties slddrw
  • Thread starter Thread starter luky
luky
How do I remove the prorpieta' field in the slddrw file which by the way does not take the same properties written on the connected 3d file?
you have to be more precise and detailed in the requests, I do not find out what you have to get and so it is difficult to give you an answer.. .
it would not be bad if you also attach files:finger:
depends on where you have to remove it:
1) Cartridge
2) separate components
3) different cutting
as already said... without a screen or a file is hard...
