tomahawk64
Good morning to all,
Can anyone please answer this problem?
inside a part I created a plate, I created parameters a, b, h, which determine the maximum size.
in the window of the property of the part (where the name of the part is entered, e.g.), I defined 3 new properties by calling them with the same name of the parameters created previously in the environment 3d.
Now I would like (if possible) to make sure that when I change the value of a parameter, I would also update those inserted in the property window. I have made several attempts (also creating a table.... and more), but in the property window the parameters do not update.
I kindly wait for an answer.
it will be trivial but x me is very important.
Thank you all in advance.
