prospects and assonometers
  • Thread starter Thread starter Simus89
Simus89
Hello, people, I need a tip, I'll explain my problem. I have a very detailed 3d and I should make some assonometric views (orthogonal, military and cavalry) and perspectives (central, angle and vertical/horizontal framework)... now it causes other probable examinations and the time that currently discards, I would like to obtain more possible representations (among those I have listed here on ) directly from the 3d in rhino , then placed on the table. Thank you.
rhino is a little lacking on the 2d... indeed: verycareful! cmq: If you want to obtain 2d vector representations of a model (which then you can import in autocad or to or whatever you want) you can use the quota/message command in tvola 2d (or _make2d): get the projections of objects that select on the 3 floors and according to the current perspective view. if you want a perspective view with a more "technical" look, go to the parallel projection for the perspective view (in view/property of the view). to put the object in the desired position or place you by the mouse the position of the room, or try to insert the coordinates of the room and destination (always in view/property of the view), there are no commands that fix the room according to a standard axiom, you have to go to set it by hand.
Note1: the projections you get are dissociated by the model, that is: if you change the model the views do not update you. . .
Note2: the command is not the maximum of effectiveness, sometimes it takes a life to process, sometimes it is imprecise in the tangences, especially if you have spiral geometries, springs and things so...
I mean, there's a little bit to lose but what you get
Good job
Unfortunately, it's like Paulo says.
On the contrary, I would be more merciful in this regard... :tongue:
another possibility is to import elsewhere the file made with rhino... type on some solid cad that has a good putting on the table (not pro/e, I recommend). You're gonna save a lot of time.
I am aware of what is lacking in certain fields : more than anything I was interested in obtaining fixed projections (horse /military / prospective various) that caught with table 2d I would have stayed on cad/ai/ps .. but apparently.... :
go to properties seen, set the parallel view, move your views as you want, there is also a plugin for the isometrics, then from the view, set the table, and you "spiattella" all in a 2d file, which you will export where you want, including illustrator. But I must say that it is not exactly the maximum extrapolar of the 2d vectors and modify them with illustrator to make tables. often, but only for explosions.
attention that the Cavalry Absonometry is impossible to obtain with a 3d, it is only theoretical, the angles will be straight only in plant.
I was wondering. but if amount the 3d made on rhino directly on cad? I have already tried and the 3d remains practically unchanged (obviously the surfaces nn are more such and the visualization remains always fildiferous), friends long ago told me that there were views presettati downloadable directly from the internet to make assonometrics and various perspectives. .. do you know something about it? Thanks again:)
edit: looking I saw that a request similar to my a few years ago was posted (http://www.cad3d.it/forum1/showthread.php?t=1968) as suggested I downloaded the "lisp asscav", a file like that (.vlx) as it loads and where is it activated? . ..sorry if I seem a bit assillent but I am fused yet another power because of the examination session ...thank you again:redface:
I'm sorry for the double-post, but I think I've solved the grain with bait.
Yeah? How do you recover? I've never seen him...
thanks for the report
theoretically in rhino or cad view 3d, all the views you can do simply by changing the room settings, from perspective to parallel view, are all isometric (since all 3 corners remain 120° ) , then x do the other types of assonometry , on cad just download a small file of library , asscav.vlx and uploading this file you can do all kinds of
