prova demo zw3d cad
be if you allow I am a technician of zw3d
no excuse .. the strong side of zw3d is just the ease of working with imported maths.if you have problems...chiedimi
much more than a technician, I would say a "forensic" :)
the problem raised by me concerns an internal bug of the modeler, referred to the "permanent naming strategy" in managing some very particular cases of imported files. probably this inconvenience was solved in the new 2019, while in all previous versions it is always necessary to perform a heal just imported external geometry.
not necessarily, often then work immediately without repair
If you go to the official zwsoft forum, you can download the model I posted and understand if you can fix the draw by following a different path;) anyway, in we do a tour on 2019.
I'm not a guy who wants to run the forums if you want to send me the file...
Okay, here we go. qui.
If you just open the model, make a regeneration, you get the error.
one of your calibers should be more present on the official forum, right?!? ;)
explanation
Imagine the zw3d file a puzzle consisting of 3 parts:
1-history
2-Mathematics
3- Graphics
Now until 2 of these remain active the file , somehow it is usable. something you messed up, or I should have the file of origin. Now I've fixed everything.
a council, create too many origins that you don't need, to do the work you did, use the section curves, is a less command.
Thank you 1000, you were great! I deduce even more so that you have a very deep knowledge of this sw ... and I would like to know how! but I have recently been on zw3d, I am trying to learn all the many commands, especially at the level of advanced surfaces. My problem is that they still play proe and solidworks a little bit, while if my initial training took place on thinkdesign, then I would certainly have used less origins. Thanks for the advice, I will see to myself much more from now on;) since that problem has arisen, I have tried to understand where I messed up, but try and try again, sometimes it worked, others did not, and then I went into chaos:) oh, thanks for the correct model. If I hadn't used zw3d, the only alternative would be thinkdesign. with all other sarebeb was a pandemonium;)
I read that 2019 has numerous improvements and functionality, which I will read more calmly in the we. In the meantime qui a highlights document. buona lettura!
look I have 2019 but I haven't opened it yet. however though reasons like thikdesign wouldn't find you.every software is to itself.
stores this..zw3d is the only true hybrid modeler, so for him solids and surfaces do not exist.
It is the operator, according to the needs that decides whether an entity is a model or a face. Then it's enough if you don't have to make an invoice:lol::lol::lol:
Okay, so to avoid unexpected invoices coming, better if for this Friday we close the reflections on zw3d and we care to pass a good we :) :)
