proxy objects autocad mechanical not editable in autocad
jim78b
hi I have autocad mechanical 2013 I saved the design and sent to another person who has autocad 2016 normal....can not modify to delete the epallinatures of autocad mechanical because it sees them as proxy objects....how can I obviate to that?
If you use mechanical elements you can't do anything with autocad. you need to use normal blocks or entities
even if you save them in normal autocad remain un editable blocks; are not called proxy entities, but... also do not appear in the block list and cannot change them
do you mean circles with numbers indicating the position of the materials in the distinct?
If you use autocad should handle them then you do a block with attribute, otherwise leave them as unchangeable blocks
Yes, but I saw that saving them in autocad 2010 converts them into normal blocks.
Okay.
Can you editate them if you need it?
I did a test and I was not able and were not even present in the block list
no I tried to explode them then delete them
- - - updated - - - -before you could not even do that with normal autocad
