lelebianconero
Hello everyone
It's been a while since I've been trying to solve the problem I'm going to expose you in a while and I can't find a solution.
I read a little around the net and decided to stop here because it seems to me the best forum among those I visited.
step to expose my problem, simplified as the files I will have to publish are several hundred.
we say that I have 4 files dwgdistinti : p.1-pag2-pag3 and p4.
for each of these I have to print only the part reported in the model, which is basically an a3 cartiglio with inside my drawing.
At the moment I don't know what kind of printer is set by default for each of these designs, but my goal is to set only the first page format and publish it all together in order to get a single multipage pdf that brings each single model in a3 format.
with the public command I arrive to load all the sheets correctly but then I can't set only once the print format and make sure that it fits for everyone, I have to open every single file, associate to all the same printer with the same features, then I can finally make the full print.
Imagine what it means to open 1000 files one by one, set the new printer, save and close everything.
to explain it in words is difficult, I hope I have succeeded but, above all, I hope someone can avoid me I am working
thanks in advance
thanks in advance
