pulley handling by belt
  • Thread starter Thread starter legnano
legnano
Hello, everyone.
the problem that I submit today concerns the creation of a cinematism (environment assembly) consisting of a belt and two pulleys. I ask you information about the modeling of the belt will have to allow the transmission of the bike from one pulley to the other the transmission ratio between the same pulleys.
greetings and thanks in advance
the wood
if it is just for design, the latest inventor rel. have the accelerator design that helps you in these things.
If you want to see her move like in reality, forget it, it's impossible.
Bye.
what you can do is assign a movement bond between the two pulleys by assigning the right transmission ratio so that, turning one, turns properly also the other. the strap remains firm, but moving it would only be a useless and heavy visual effect for the computer.
Okay, the movement bond works well, that's what I needed for the moment.
Thanks again
I.
