put in the table
  • Thread starter Thread starter mauro1972
mauro1972
Good day to all, I'm so dark.
How do you get a table set with visi 15 to be able to then quote a 3d design?
by clicking on on/off table nothing happens to me.
Hello, Mauro, I don't know what the most famous cads do, but with my mind, you have to "compile" it.
now I use newer versions, but the operation should not be too different (it will be +/- to v25, if they had kept the old nomenclature):
Activated the mit, you should find a bar between the icons on the left called "manager m.i.t." that makes you appear full menu to the right;
In there you should find
  1. the submenu to choose from which origin to extract individual views,
  2. the subm. to choose what view to create (plant/prospect/profile/. . . ),
  3. the subm. for sections (real/long profile/. . . )
  4. il sottom. per choose what to represent in 2d (between already existing views, solids of the 3d environment, etc.) with also a "tree" that lists the available solids, not to have to jump in and out between 3d and m.i.t.,
  5. other menus for prints and configurations, which I don't even remember now, but that could also have been different from how they are now, but something is for sure.
in practice if in 3d you have a solid, in m.i.t. you must first select by hand (unless not often the whole 3d file in a single 2d view) and then choose the single view or the 4 automatic views, enabling or not the individual flags of customization, then you should have on the top edge a green icon that is to click to see the view attached to the pointer and that you can now place compared to xy.
quotas are not created automatically, but you have to put them, as they were in the 3d environment.editing commands are "scrowded" and you can't make cam.
When you change a solid, you should warn yourself if it is already present in m.i.t., so you know that you will have to update it by hand or reload the file to make it by autom. will not update all the quotas, only the views and certain quotations that can recognize, so be careful about the changes and the relative views, which remain updated.
you can't change in m.i.t. by trusting that you reverberate in 3d, as they know how to make bigger cads.
the views are an aggregate that if you want to change (for some reason legibility/factability/business yours) you must dissolve it, and will no longer be hooked to its 3d model...
the views (aggregate or not) you can copying in the 3d environment, but the copy is no longer connected to the model.
you should still have a help (f1) written decently and in Italian.
Always keep in mind that it's a pretty dated version and I could remember badly.
Hopefully you're enough to start, good work,
Reborn.
