devildani88
Hello
I have a sheet falling where the same block is present n times.
the above block has a number of attributes that have different values in n blocks.
I would like to put on different layers the blocks that have for a given attribute a specific value. Therefore I would like to know if there is a command for which you can select for "admitted value".
given the attribute "code" I want to select between all the blocks those that have value 1 to the attribute "code". Once selected I can put them on the different layer.
