quality surfaces and spheres.. .
  • Thread starter Thread starter enry79
enry79
curiosity not found in the forum:
how do you vary the quality of the "triangolini" used in pro/e to generate surfaces?
I explain, how to increase the detail of a sphere, in the sense that I see them "smused" and not beautiful rounds.
how to vary this parameter I looked a little everywhere but I found nothing!
I wait for lumi....
I guess you mean visualization. .
Well... you have to go under display (it seems that it is in the second menu from left) and increase the quality from 3 up.. (Put 7-8. is suff!) and then put the option "view small surfaces".
If you are working with models with "complex" surfaces use these settings and you will see that proe will be more tasty to use. .
one of the things I love about proe is just the quality of visualization!
then: displays -> display setting -> model display and in the third "window" (which in Italian is called shadow) snacks "small surfaces" and imposed qualities to 8 (for example).
would you tell me the parameters to be inserted in the config.pro?
I found one and it is
Skip_small_surfaces no
the other to define quality?
