drake
I have a problem about the quality of displaying a curved beam. I would like to point out that in practice I have never had such a need not taking care of "curve" elements, so I don't know what else to do more than I have already done.
I am modeling a wooden beam with circular curvature and at the time of inserting the secondary beams I realized that I have a visual problem that does not allow me to overlap the curves even if perfectly equal.
in the following image I will show you the problem
as you can see there is no perfect overlap, although the sketch line is perfect.
the graphic settings of the drawing are as follows:
the problem is that in drawing stage I can not accept to print a drawing so, it is not presentable. the incorrect display I can accept it in the model phase and in the setting stage, but at the time of the drafting of the definitive boards no! how can I do to solve the problem? Thank you.
as you can see there is no perfect overlap, although the sketch line is perfect.the graphic settings of the drawing are as follows:
