quantity
  • Thread starter Thread starter Freddygol
Freddygol
Good afternoon,
by making the table of a particular, I cannot insert the quantity of the particular mounted in the x (example) axieme automatically. Is there a way to do that?? ? thanks to who will answer!! !
I've been trying for a while, but I can't. I do everything to point 5 but then I can't understand how to "report" the value in the part, to me the property (which I called n pz) made in point 1 does not update me..... .
1-create in part a property (name it for example qt pezzi), the value field leave it white.
2- in the drawing insert the separate materials and add a column with the property qt pezzi3-click once on column cell qt pezzi of the interested party and when the text editor appears, select the equation symbol; now select the column cell quantity and confirm.
in the cell qt pezzi the value of the quantities with the equation symbol at the bottom right.
4- Now double-click on the newly modified cell and a window should appear where you ask if you keep the link to the property of the part or interrupt it; select to keep it and after the cell has activated click fuporous from the table to exit the cell modification.
5- Now the property is connected to separate materials.
Yes, either written in the last box of the list, or by editing the list at the top right in the property window....... .
there are developments, the piece on which I was trying is a detail that I downloaded from the contents of the catalog of solidworks. the piece is full of variables and the list of properties is full of various items. If I do the procedure with parts and assemblies made by me it works......
And the table?
indeed no, do not attach anything because you have 2020 and not 2015 as written in your profile and so I can't open it
And the table?
Good morning, I welcome this discussion
work on sw20, once you create this column and perform this connection operation, how can I repeat it on all cells of the column? Thank you.
