M_free
it was not help the video..." I solved the problems!!!". ..thank you so much it was enough to put a coincidence relationship between normal plans to the component tree!Maybe you need help... (if you want to try posting the file, I try to bind it right)
now a new question: "Setting gear relationship between two toothed wheels that gear up and setting the correct ratio between the teeth they rotate correctly but more than a freeing you have the rolling of the polars or the teeth you connect is normal? can you specify the contact between solids even outside the animation environment? Thank you!
