Mold
I have a manual 3-axis anayak fv 4 milling machine from the early 90s that works well.
this milling machine has a display that allows you to perform the tools and to measure the running of the table during the manual movement.
I would like to know if the following workflow will allow me to successfully complete my mold.
flow related to male dowel
1. the details are 2 shells in size abs 60 x 40 x 7 mm
2. I have a pedrotti stand 246 x 246 mm with tile reported - vent the old dowel
3. purchase a steel tile 1.2311 or 1.2378
3. I put the tile on the milling machine and the squadron in x, y to enter the stab
4. I put the tile on the milling machine and make the holes for thermostating
5. I put the dowel on the milling machine and make the holes for extractors and punches - lift the holes
6. I put the tile on the milling machine and work in z so as to leave to relief the protrusion of the printer part.
the protrusion will be in the form of a cap with an overmetal of 2 or 3 mm compared to the final geometry.
Of course I can't precisely check the thickness of the overmetal because the milling machine is manual.
7. I make an electrode finish in graphite and then I carry the dowel at a supplier for electroerosion.
8. I see the twelfth on the stand
9. Supposing I have ready the other dowel I try to close it and see the match with the blue of prussia.
Does this workflow make sense?
I'll do it with the manual cut?
Something missing?
How do I intervene if the closure with the blue of prussia is not zero?
I thank all those who answer me.
Something missing?
