reggio
hi, beginning from the annex,
It'll look like a banality but I can't get the 2 floors all on the same side... I do the same operations, on the same side, using the same dx reference plan, but one is "before" and the other "back".... how can I put them all on one side?
- I then wanted to try to assign an angle of 180° to try to turn it on the right side, but says "select plan and linear edge to define new reference plan" ... eehhhh??? ? What does that mean? What should I do to rotate a plan?
- when I create a plan, select the cylinder then give it a main floor as reference (frontal,superior,destro): Why if I give a plan that "cuts" the circle from north to south, the new plan goes to east or west??? Orthogonal? would it not be + logical that it remained aligned to the indicated and simply tangent plane? How are you doing?
