questions about styles, iproperties and designs
  • Thread starter Thread starter aomaxi
aomaxi
hello to all, I have some problems with managing styles.
I created an idw file template with my custom cartiglio and when I realize a design I go on new, I select it and create a view by associating the ipt model.
all right here, every time however reset the styles of the layers that I modified in the idw file (and a message appears to me) and this is the first problem.
the second is a little more complex to explain. I have pieces that are equal on different assemblies, how do I copy the masses at the table by associating them with another model? so you can update your cartiglio data with the correct iproperties?
I try to answer the first: you have to update your styles with respect to the library, otherwise the error message that he does not know which is the correct one.
updates the styles in the library with those of the idw template and then everything should work.
I tried to read the guide but I didn't really understand how to do it.. .
Now I am without inv, I go to memory: Open the idw template, go to management and click on updated styles and standards of course check that you use local styles (idw) to upgrade your libraries
Good morning, everyone. I wanted to know if there is a possibility to create a supplier table to be used in the vendor iproperties, type drop-down menu to mean to avoid having to always write manually.
thanks in advance
thanks in advance
I've seen it for the quota values on the parameters, so I think I'd like to think about it. sia possibile.
1560759489827.webpwhen I try to update it gives me this popup.. .
hi, I solved this problem by creating a library, based on iso, from the library center that you find on windows start. at this point you personalize what you need and then from the tab styles and rules click save.
I hope I've helped you.
make a copy of the date design folder. open inventor without open files and go on projects. set the active project on "reading and writing". at this point open the idw file with the changes made and go to the ribbon management. to the left select the "Save" icon where there is styles and norms. at this point all idw settings will be saved in the date design folder that will be synchronized with idw. close the file and return the project to "read only". Let me know. Hi.
I answer the second question, make a copy of the board then use the command "replace model reference" and point it to the model you want.
I am using this method but I happen that when I go to save it opens the popup that asks me to update the references and so doing I also update the design file of origin. . Otherwise you don't save it and I find myself with two equal files... What a disaster
