questions for those who use advance steel
  • Thread starter Thread starter ilarspa
ilarspa
Hello, I recently purchased the advance steel program, coming from a multi-year experience with prosteel, I would have a first series of questions about problems/dubs encountered during modeling:
1) Can you change the name of the views by selecting the object on the model, instead of the rename of the “project management” window?
2) is it normal that each object (profiles, views,...) is inserted by default on the work layer, rather than in the respective layers? is there a set to do?
3) and possibly, you can create other dedicated layers (e.g. floors separated by views, columns separated by beams etc...) and let go of each type of object in your layer instead of moving them by hand one by one?
4) is it possible to display the profile name in the model without having to do 2d views every time to check?
5) is it possible to clean the profile database from the various foreign databases? (as you did in the prosteel) otherwise every time a very long list appears and to look for a profile it takes a lot of time
6) very often (not always) does not work the advance button to visualize isometric: is there any limitation in use?
7) why does the license we received tell me that it is valid for about 45 days and is not definitive?
8) we have created the rooms and assigned a name each to make the assemblies: If we generate all the views that are automatically impounded, there is no room name and I cannot recognize them. How do you activate the name? even the name of the profiles does not come, while if we do the manual views you.
9) is it possible to order labelling styles alphabetically? otherwise there is a very long list and to find one....
10) we have created a custom labeling style and saved it but, when I go to assign the style in the process manager, it does not appear on the list and therefore I cannot recall it. How come?
11) if we want to change layers, collars etc. and use the “autocad brush” changes all properties, including profile type, insertion point etc...: is there an alternative system or settings to change to avoid it?
12) in case of multiple copying: can you always lock the filter on x or y instead of having to give it back for each single piece?
13) we cannot find the pipe database, to add a measure: where is it? is it possible to have a list with the names of the profile classes to be used, corresponding to our standards?
may seem like an interrogation, but unfortunately also the course of advance does not explain many, and the problems arrive at the time of use.
I thank in advance anyone who answers me even to some of these questions.
Thanks for now
from the questions you ask, it seems quite lacunous to me the course you did.
But how many days does it last?
Hello the Arspa
to our study they proposed to replace prosteel with advance steel but from what little I could understand there is no manualistic in Italian, is it true?
the course of two days seems a little bit short, if it is enough to learn this program and be productive immediately?
manuals in Italian do not exist. and I can assure you that it is really difficult. especially if you come from prosteel like me.
Thank you very much. Given your experience, I hope my company won't move to advance steel.
