questions on continuous facade - roof - pillars
  • Thread starter Thread starter VLK
VLK
Hopefully you've all spent a good summer (nn like the undersigned at lavura') I would have some easy to ask the most experienced.
1) Transparent objects (such as glass continuous facade panels, windows etc) are displayed in transparent 3d views while in non-transparent view. If you want to see not transparent elements in 3d views there is an option that I can use?(the only solution I found was to bring to 0 the transparency of the glass material but it seems to me the ideal solution because it is relocated in all 3d views)
2) I have to build an irregular pyramid-shaped glazed cover of which I know the base and position of the summit. I tried with the roof command from perimeter but nn I can position the tilt arrows correctly and always gives me a mistake. (the only solution to calculate by hand the inclinations of the bonnets and insert them numerically but the resulate nn is never accurate).some knows how to tell me the best way to proceed?
3) some elements of the project (structural pillars, solo edges etc) which are covered by a small layer of plaster for example 1.5 cm remain rightly hidden as long as I am with a relatively close view but when I zoom from further on they begin to see more and more. I don't know if any of you happen or if they are actually drawn as they see the wrong monitors. Is there any kind of parameter to increase the accuracy of hidden or similar 3d views?
thank you very much in advance and good work to all:finger:
like you, I have also worked...in my life! :mixed:
I try to answer you hoping to be clear.
1) the advice he can give you is to change the display settings for the category (in your case glass) with the color you prefer. I think that's enough. the setting, to go to change for each view, will keep you even when printing.
2) to help you I should see how construction is. Maybe not position the tilt arrows correctly.
3) I also happen to myself in some cases, but the lines are not printed...are data errors from the zoom.
I hope I've been helpful.
this and a sketch of how it should come at least until I want to insert grid lines on the sloping faces that follow the 2 vertical and horizontal base alignments. ..problems on problems:tongue:
thanks for the answers, I trust in you or I will never end
1 -using the roof command, it creates many bonfires (one by one) how many are those of the roof, with the command "right by perimeter" and with the "tilt arrow" assigns the share of the river and that of the summit.
complete with the join command.
assigns the glass material to the roof.
2 - or, it uses the volumetrics (conceptual), once the "surface" of the roof is created, at the same time it allocates a roof with the command "surface roof"
p.s. I modified the title of the message, so as to highlight its content for other users (and for the search query)
Thanks for the advice, I solved point 2 and 3 but on point 1 nothing to do.
If I change the color of the reason by putting it for example white this remains transparent unless I change the transparency setting that is not changeable view for view but the properties of the glass material in general.
to specify I would like to make a table with 2 equal assonometers, only in one glass must be separated and in the other not.
Does anyone have any ideas?
Thank you very much
v
