Messerschmitt
I press that I just started studying this problem, so I need more than just an idea about how to make this mechanism work.
I need to unleash a hanging object suddenly, moving on vertical guides and weighing about 2 tons.
This release system must also work in the absence of electricity, because when this is missing this object should be released automatically.
the first idea that came to me is a pin, supporting the weight, which is paraded by a hole through a pneumatic cylinder connected to a control unit, with normally open solenoid valve, kept closed feeding it. If the current is missing, the valve goes unloaded, the cylinder receives pressure and parades the pin. What do you say? I have some doubts about the materials to use and the possibility that the pin remains framed.
I also wondered if maybe, on the market, there is some quick release mechanism that could be suitable for purpose. Are you aware of this?
I remain waiting to hear your ideas and opinions. :biggrin:
