quick tap, depression and high temperatures
  • Thread starter Thread starter LuPo_81
LuPo_81
I have to make a mould to make laboratory samples, and there is a need to create a depression inside the mold. I would like to use a metal suction tube (to be taken into account that the mold takes place at 150°) that runs out of the mold and out of the press plates, and at the end of the pipe I would like to put a quick pneumatic coupling to connect to the intake compressor.
the quick tap naturally should be put on the compressor side, but it also works properly in depression? Moreover the pipe will be about 200mm long, the more I can not do because of the conformation of the press. according to you 200mm of tube how much heat does it dispose? Will the tap work correctly at that temperature?
