quotas for a new point 0
  • Thread starter Thread starter GiusyI
GiusyI
I apologize in advance if I cannot be clear and especially if I may not be up to it but I am self-taught and in these years I have learned a lot thanks to your comments and suggestions. I'm an archaeologist and we make a very limited use of autocad and say that for the simplest things I'm doing pretty well. in recent days I realized a relief with instrument gps, I reworked everything (the relief is a portion of a Roman villa) and now the client makes me a request and I do not know how to do. Of course all the beaten points have their absolute share slm but now he asks me, to have a more immediate reading of the difference of quota between one point and another, to place 0 on a very precise point and from there to have all the other points with quotas relative to this zero (I don't know if I have explained). Is there a possibility with autocad? I have a version 2018. Thank you very much and I'm sorry if I've stretched out. g.
in my opinion, create a new dwg, insert the relief as xref and move the point in question to quota z=0, your relief remains such and which, the customer will have the reading of quotas as best he believes.
is easy enough if you check the icon of theucs as origin the point where you intend to assign quota 0
Enables realistic or conceptual view, so that the icon of the bird is more visible, then assigns to the variable "ucsicon" value 3 so that the icon always appears at the origin.
then make sure that the bird always appears at the origin by clicking on the icon dedicated to this purpose in the menu 'modelling 3d'
pass over the mouse icon and when it takes on a yellowish color with the right click select the "origin" item.
then move to the point where you want to assign 0 quota and click on it.
The icon of the bird will appear no longer on the left side of the screen but at the point you have chosen. the coordinates of all other points will be recalculated.
during all these operations make sure that the icon z axis is always oriented up. in case you move it up with the mouse.
in the video there are all the steps you will have to perform in order to have a manageable ucs with more ease
I always propose more Moroccan methods.
In fact, the method proposed by rpor66 It is more indicated, because in the case my method was adopted, if the contractor went to assign the "global" attribute to the ucs, the coordinates would return those of the original relief performed with the gps.
unless you save the bird once you allocate the origin to the point you want to have quota 0.
