quotas from numbers to letters
  • Thread starter Thread starter Luciox
Luciox
Sorry, but I couldn't find anything about my dilemma.
How do I replace the number of the quota with a letter to my choice? Unfortunately I don't remember it and it must be very easy.
thank you in advance to those who can answer me.
double click on the quota and change the name; back to the quota, right click and choose to view the names
just thanks I almost got there, cmq to me with the double clik does nothing to me, it works by doing: right click "change formula" I put the new "name" and send and then I do right and "show all names" and the game and done. Maybe I have different settings?
But by this process I convert them all if I had to do only one?
see if the attached images answer the question
:eek: thank you very much to all
leso in fact is also a little my fault that I did not specify some things, I then possess the varsion st1 solid edge that however at the end for that command is almost equal.
you caught us in the great hunter thanks
Thanks again so many you saved my life:biggrin:
I hold on to the discussion since I have almost the same problem.. I have to change the quota text only in the draft form if ( version 16 ).
I have to quote a thread g 3/8 and I would like to quote it exact ( instead of the numerical value I would like to use the quotation according to regulations ) in the table otherwise the prof. at the exam ... :angry:
Would someone help me?
do so:
in the model do the threaded hole exactly as it serves, ie choosing from the drop-down menu the thread g 3/8", then in the draft:
1) share normally
2) inhibit the display of the quota value
3) in the properties of the quota text, enter the writing %ts as pre-text, in this way if you understand that you must go to take the value of the quota inserted in model 3d.
Thank you very much ... so the quota I have to change already from 3d... thank you very much
