Mano63
Thank you, now it's all clear! what you showed me works exactly the same way to me too. I was obviously wrong to express myself. the quota that I have to insert has a particularity: is composed of the only text that is detached from the hypothetical quota line of a x value. the quota line "invisible must coincide with the side of the polylinea and the final effect is a text along the side of the polylinea. for this I was talking about a single click (clicking the side you should place the quota "only text") instead you click 2: one to select the side and one to place the quota. Perhaps with dim what I look for is impossible, but still thank you!you can quote directly the side, it also works with the inserted osnap, but if you remove it (osmode = 0) it is better.. .
