quotas to control
  • Thread starter Thread starter Max-C
Max-C
Good day to all,
I have heard that it is possible to mark the quotas so that they are checked and, if not correct contested the component.
I heard that this "indication" and look for the quota.
there are two ways to look for the quota:
1. circled by a circle
2. circled in a rectangle
Could you tell me what's right?
thanks and good holidays to all:)
circled by a circle, here where we work we use the circle.
the box is used for the odds in "real location" that I never use luck:wink:
Thank you so much! :
Can you explain what "true position" means?
so it seems that in the car you have to take exactly that quota.
Excuse me if I reassemble this old discussion but today I looked for inspection quotas and I got out this page.http://autocad.compago.it/manuale2011/filesaug/ws1a9193826455f5ff15d97a810d5ab4f18b-7eed.phpcould you tell me what difference is between the circled quota as quoted and the "racchiusa" as indicated in the link?
in theory that circle is of inspection while the rectangular is the bad variant of the untrue quota, used to represent dimensions on interrupted views.
then depends on what you write in it and the circumstances
It's that on solidworks the circle gives me as an inspection and that link almost sent me off the road.
