quotation isometric view
  • Thread starter Thread starter anfaloni
anfaloni
I'm sneaking on something. given to appurate the comfort of the layout space on which you can freely quote orthogonal views without fear of the scale as automatically read from the window on which we quo.
what I ask myself is why it is not possible to quote a perspective view from the layout space and how to succeed. . Trying to do it from the model space. ..quoting in the standard way defining orthogonal plans on which to quote, then going into the layout space actually the perspective view also brings with it the odds that also appear in perspective...it would only take a way to make the text height of the quotas and the arrows of the altitude suitable for the scale on which it is expressed in the layout space.. .
What do you say?
Hello aphalonians
I don't know if it's your case.
in my autocad application, years ago, I had programmed a bar for isometric drawing with quotas.
In practice I had created 2 blocks for the terminals of the quotas called tract1 and tract 2 with oblique lines.
I then created the scripts you see below.
button 2 changes the type of horizontal-vertical isometry.
In this way I produce flat isometric designs (not 3d).
Hello aphalonians
Hi.View attachment 42849
Hello and thank you for the answer. say they produce 2d drawings but the object I see quoted is a 3d on space model quoted on the different planes you define always on the model space? from space layout then hanging is like ru see a 2d. you mean this? to me the thing that doesn't come back is that if for example on the llayout you have a 1:50 scale chart and represent the solid in isometric view with a 1:10 scale window as well as the model also quotas that therefore as height text nn are more compatible with the 1:50...c folder is way to bind the characteristics of the model space at the scale of the window used in the layout space?
by drawing 2d I mean flat tilted lines.
to understand us see sheet below.
I do not use paper space, but I enlarge quotas or texts with special commands.
So, I think, my solution is not good for what you ask.
I know what you're saying. the odds in assonometric view do them normally once you impose with the sl command assonometrically. at that point then with f5 change the direction of the assonometric plan and quoti the other oblique sides and if steps intervine on the quotas daa edita style of quota. they are siciro that you can also do dialogue from model to layout. I'll tell you what I find... but you might be useful.
Hey, here I am to update you. Then you can do it!. take the 3d model that you carry out in the model space, define 3 main plots of quotation so that they are then readable in the right direction from the layout space, and define a quotation style by dividing the "annotative" property that will tie this style to the features of the display scale in the layout. at this point if you go to the layout space where you put the case you want to see the solid quoted in an isometric way in perspective 1:20 scale you will see the odds all in isometric view and scaled for the format you entered in the layout space. if you want to make windows with different stairs, go back to the layout and to a quota from the annotative properties add the missing formats..poi turn off all the quotas so as to communicate also to them the stairs added. You'll see everything goes well.
