quotation threads
  • Thread starter Thread starter marcofa
marcofa
after enabling axes and threads in the views and sections, I can't make the indication m (m10....m20) appear at the height, but the diameter remains (in the section the diameter of the pre-light)
Mar
in the drafting you have to look for the function that allows you to quote the thread. case faces is a function represented by a thread. not to be confused with the function for creation of linear quotas. using it will automatically appear on the view both the diameter in m and the depth
I had already used the command, but it always gave me forbidden sense, I found that it is necessary to zoom in and point carefully the thinnest lines of the outside thread.
Mar
Yes. excuse the banality but I took it for granted that you select the icon gist and the right line;-)
