Thanks for the answer.It's enough for me. the center will be equal to that of the cap so with a tastat is obtained automatically, at the most put it as an auxiliary quota.
sure to know what machine is made helps
but do you have the basics of technical design?What angle should I quote? and where should I put it in?
the axes of the holes intersect in a hypothetical center, which in theory
Obviously my question has not been understood.but do you have the basics of technical design?
the axes of the holes intersect in a hypothetical center, which in theory is the same as the radius of the cap (in theory because for functional reasons it may also not be so). in which view would you draw these axes? if the axes intersect means that they are not parallel then form a...
concrete
b angle
c sandwich with scamorza
But if you had drawn the views and studied them, you wouldn't have asked such a question.
you have three views:frontal (in which you see the central ferritoia), lateral (in which you see the radius of the cap), plant.Where am I going to write the quota?
I think we're almost there.If you ask me what view you have to put angular quotas a doubt about the knowledge I allow myself to have it.
I read student, not mechanical engineer, which then a title says little.
I did not give a direct answer with all the steps, put a sketch, because reasoning and the best way to learn.
But since...
in the side view draws the axes
quote the angles between the axes and put the quotas at a suitable distance, to the scale of representation, from the spherical edge.
do a decomposed section on one of the holes (or do a detail) and quote the hole diameter.
If you prefer, and can replace it, instead of side view do the section.
It seems to me an all-somato banal piece that does not require great maneuvers and not even so many odds to cross and create trouble. if I still have not understood your question I am going to and wait for the continuation of the post and your result
I came to the coffee and digestive so... prosit
exact! i have 10 normal holes at the spherical surface so 10 non-complanaries axles!you have two axes that intersect at one point and that of course they are not comlanaries.
do i understand?
How much did you get in geometry?exact! I have 10 normal holes at the spherical surface so 10 non-complanaries axles!
30 also in geometry :dHow much did you get in geometry?
Come on, I'm sorry, I'm trying to get rid of it, too. two axes intersecting at one point are common always. you can follow three roads:
1. take two holes and quota the angle between the axes on a view is the section of the object made on the passing plane to the center of the cap and the centers of the two holes. then put a note and write that the holes are all like two to two.pro: you have a mathematically elegant and impeccable representationagainst: you will be taken by your ass to life by the shop boss who, trivially, will have no way to measure and/or verify those odds.
2. in plant quoti the distance from the center of the floor sphere [equatoriale] on which all the holes lie, and then quoti the length of the arc between the centers. in a note write that the holes must have the axis pointed towards the center of the spherepro: continue to have a geometrically unexceptionable representation and give the operator the possibility to make a trace using simple mechanical blades.against:the workshop leader will come looking for you with the key of 24 and a false smile and will kindly ask you what the fuck you need the holes facing the center of the ball.
3. you realize that, given the reduced thickness of the sheet, the fact that the holes are with axes towards the center of the cap, or that they are towards the center of the above equatorial circle, at facts nothing changes, and then you do a section directly on the equatorial plane where you will draw and quota the various boards. on each axis you will put a central tolerance of 0.5° and so the operator will understand that the holes can do them with the hand drill and do not need a five-axis working center and an aerospace engineer to realize that set of holes.pro: for today you will avoid meeting the chief workshop, which notoriously is part of a bad category of people. you will also pay the realization of that piece at least one third.against: you gave up a requirement that could be of vital functional importance.
In fact, they lie on the surface of a cone of which you could quote the opening in steradianti...no, I'm joking!30 also in geometry :d
Of course taken at two to two, the axes are flattered, but taken together, they are at all!
Well, I'm glad, but on the forum let's say you.However geometric disputes aside I think that you have centered in full the answer and probably in the end I will follow the third road that indicated, in order to avoid shoots of wrath by shop leaders (it is perhaps the most rational way since the convergence of axes in the center of the spherical cap is not a functional requirement)!
