quote diameters in detail without axis
  • Thread starter Thread starter Tarkus
Tarkus
This topic I'm sure it was treated more than once, but the "search" is not helping me.
as from title, made a detail of a section of a tree (the unloading gorge for grinding), and this detail does not arrive until the axis of revolution.
How do I quote diameters?
thanks to all
Enlargement apart.
or put the director in which you indicate the type of throat and the reference unit
Enlargement apart.
no indication of legislation, I must indicate the diameters.
What do you mean by magnification apart?
Yes. Excuse me.
I meant view in detail.
the rectification gorges are unified, so in reality it would be enough to indicate with a director and to recall the type of throat and its norm
Yes. Excuse me.
Maybe you didn't read well.
I already have a detailed view that I must quote, and the throat is not unified.
and anyway the problem remains, how can you quote?
You could put an image of detail, I'm struggling to understand how the real situation is
made a detail of a section of a tree (the unloading throat for grinding), and this detail does not reach until the axis of revolution.
right click on the view / automatic axis lines
then, if necessary, remove the "visible" flag to the axis.
Do I understand?
but it does not get to the axis, so it does not succeed (or at least I can't that I'm trying:unsure:).
I tried to make a particular that understands the axis and then to cut it out but it doesn't seem to be possible to cut out a particular (I hope to be I dismembered);
I tried to draw a sketch line to use it as an axis but then I couldn't hide it;
only parametric solution to which I have arrived is a guide linked to the model parameters, perhaps appropriately renamed to remember what has been done.. .1621578270616.png
1621578419917.pngor, _porcata_ that came to mind writing, I do the sketch (but it will not be parametric), I put the diameter quota, I reopen the sketch and set the line axis of support to "only sketch" and so disappear but the diameter quota holds. 1621578486394.pngpersonally I would go of solution director + parameters that are a mess and more stuff you fix yourself better I am.
But come on, I tried half an hour and I couldn't, I looked back and "auto-assisted line" worked.! excellent solution
