quote in abaco
  • Thread starter Thread starter A-lisa
A-lisa
How's everybody doing? :redface: is there still someone at work?
I would like to know if there is a possibility of inserting the size indicated by a quota in an abacus. Thanks again, as always!
I don't think there's the odds abacus... but you mean automatically? But what do you need?
hello tristan, thank you for the answer.
when we present the municipal practice, we must demonstrate how the surfaces are calculated, some technicians do not trust the value subscribed by a professional, (recovered automatically by an abacus) also want to understand "how you get", and do not have all the twists. until some time ago, we put all these accounts in a table excel and glued its image, waiting for revit to mature.. I look for a parameter that allows to "direct" to the abbot to report the value of a certain quota. You know if it exists?
I take advantage to congratulate you for all the media you can give, I am a "autocad daughter" and it was hard to jump on revit (it is still now but I have confidence).
use : export
allows you to save a .html file in which air calculations are contained (all types of areas) as well as graphic demonstration.
the file can be used in various ways (copy, edit, save in other formats), and by copy/paste (ctrl+c - ctrl+v) import into revit
Thanks gfrank. I didn't know him! I'll try it as soon as I can and let you know. See you soon.
