quote
  • Thread starter Thread starter PAnz3r™
PAnz3r™
question:
Ever since I've been working with proes, I wondered if someone puts the tolerances directly on the model and then makes them visible on the table using "show annotations model", I never used them I've ever found them so well the few times I've tried, especially because when you make them choose they are all confused and I do first to put them by hand. .
I'm sure I'm wrong, if you give me some straight chance I'll find out that I've been ciula until now...:frown:
I usually prefer to requote a new ex table for the following reasons:
- very often it takes more time to reset the recovered quotas with "show model annotations" than to create new ones.
- I realized that not always the odds used for modeling are useful for construction.
I prefer to avoid someone changing my odds, by mistake or voluntarily, in the single table, without having the project or at least the open set.
modeling, construction and control quotas do not always coincide.
the design goes accordingly.
personally simple pieces, the model then considering the use of the quotas of the modeling.
more complicated pieces, I come to make the table with ex-novo quotas.
quotas with special tolerances, I am putting them more and more in the model, so much the mask to insert them, is the same as the 2d.
