cougarz
work with wf5 pdmlink and windows 7, with 4 gb of ram. every time I approach 2 giga it blocks me proe. I knew that proe had a limit on the ram bypass, do you understand?
in fact it is the only solution if you still use 32 bits. :smile:with windows xp and wf5 32 bits rub over 3 gb of ram with the set described in this discussion:
http://www.cad3d.it/forum1/showthread.php?t=15910prova.
but you are sure that you can do with windows 7, but I did not notice big differences when in xtop process reaches the giga the program closes.I spoke to a systemist and solved the problem.
if you need
just add in the file c:\boot.ini the instruction
/3gb
in this way xp exploits all the ram that can (about 3gb)
My experience stops herewindows xp e wf5 32.
